Hi,
I’ve been using the proofgrade materials and have used under 20 sheets in the time I’ve been using my glowforge… Granted they’re intricate cuttings…
But I noticed the crumbtray and inside of the glowforge is getting very sticky. Is there a suggested solution on how to clean this? Is this normal?
You don’t want the inside of the cover to get too sticky or cloudy. Not that it will affect the operation of the 'Forge, but it will hinder your ability to watch the awesomeness in action!!
Thanks! I had some Simple Green around and that did the trick. I just hadn’t seen that with other laser cutters I’ve used… Usually it wouldn’t bother me but it was starting to look yellowish on the front flap so I figured I should address it.
Thanks again! Luckily no visible residue on the lid or lenses :]
We appreciate the answer @marmak3261, that’s right. I’m going to close this thread - if you have any additional questions, go ahead and post a new topic.
