Ditto what @markevans36301 said - I find there is sometimes tiny movement after I’ve cut (if the material has any flex), so I do all the engraving and scoring first, and the cut last
ROTFLMAO!!! I made the honeycomb pins out of 1/8 wood and acrylic. The acrylic ones have not even cracked. After 10-15 times the acrylic pins seem to get smaller. When that happens they lose their ability to hold down material.
I tried a batch of acrylic ones too, but they do bend a little bit over time, making them less effective than the wood…I wound up just going back to draftboard.
Unshielded magnets bad, If you wave a thin screwdriver loosely in your fingers at the height above the magnet about the same as the cutting head and you can feel the pull it can create problems for your machine.
Okay, speaking of the pins, this reminds me of something I have been wondering. Some of my pins fit so loosely in the honeycomb that they really don’t hold anything. But if I put them in a different hole, they are pretty tight. What causes that, is it the pins are worn out? Surely it wouldn’t be different sized holes on the bed, right? Or is it that my baltic birch is so warped nothing would hold it flat enough? It’s really not an issue, except for when I have a really warped piece of proofgrade, where I can only use the pins on the very back and very front, and lots of times, I can’t get the pins to hold it down flat.
So the redheart insert is glued into an engraved pocket on the underside of the lid, which is a through-cut inlay piece. Alignment was key, so I needed the pocket to be perfectly placed on the underside of the lid. While I may have been able to engrave the two pieces of inlay separately, the chances of getting it right were greatly reduced compared to assembling first, then using a jig to setup the engrave after the glue dried.
So, it’s really situational… but there are definitely cases where engraving after the cut is a good plan.
It’s this exactly - it’s a wavy grid so they connect at different points in the wave - I often find that if a pin is loose one direction, if I rotate it 90 degrees it’ll be tight
I’m sure eventually you’ll be thinning down the edges of your pins, but I’ve been using the same ones for over a year now (so 50+ times minimum) and I haven’t run into that yet (mine are plywood)
