Has anyone else had problems with the cherry not staying attached to the core?
I make magnets with quotes engraved on them, and have about half a sheet of unusable (unsellable, anyway) of product because the inside of an “e” or or “O” or other similar letter comes off during the unmasking. And I’m pretty gentle.
Anyway, is this just the nature of the product, or am I getting bum sheets?
Try shallower engraves, and use a bolder font to get the “depth” you’re looking for. Looks like you’re hitting the glue layer, and that small bit of wood just can’t hold…
Having cut the same file from both the medium and thick cherry ply, I was surprised that the thick actually weighed less than the medium.
So there is a difference in composition.
Yeah, that happens if you don’t remove the masking very carefully from tiny little extrusions…on any of the materials. If the island is really tiny, it’s going to be prone to breaking with the least amount of pressure.
I use either the Gorilla tape, or a plastic razor blade, to carefully scrape the masking off starting at one edge. The razor blade works better on teeny little islands.
When you use the tape, press it on but not too firmly on the little extrusions - if you break them by pressing down too hard on them, they’re going to come out of there. When you peel off the tape, pull it back on itself, not straight up.
And you can always glue the little dot back in with a touch of wood glue. It will last longer than the other ones that didn’t fall out.
To help pinpoint the problem, are you using default Proofgrade settings? Which one did you chose?
The thick ply seems to have a different core. I have not had this problem before, but that might be dependent on the font. It has to be frustrating.
Hard to tell if it’s that sheet unless you have tried it on another, which you don’t want to mar. Have you tried to separate the top veneer manual, such as on an edge, to see if that sheet doesn’t have good adhesion? Good question to post.
