I started 2 hr engrave/cut job, non-proofgrade (1/4" walnut).
I’ve been testing small pieces on this all afternoon.
The first operation (there are three, engrave/engrave/cut) was a smaller engrave area. that engraved fine. then the next operation was supposed to start. the laser head is moving over the engrave area, but nothing is happening.
stopped the job. calibrated. tried again with the first operation on ignore. ran it again (waiting for the full engrave to show up on the preview), same thing. laser head moves, no laser firing.
rebooted the GF, refreshed the GFUI, restarted the job. same settings, same location, ignore first engrave. it began the 2nd engrave operation again, no laser firing.
these were all started between 7 and 7:30pm eastern time.
ok, small update. i tried engraving one of my test pieces in a top corner of the wood that wouldn’t be used (i dont’ want to move this piece so i can try to engrave the rest in the proper location next to the first engrave). it started to engrave fine, so i lifted the lid. the settings are exactly the same as what i have for the big job.
so i loaded the original job up again, waited for the preview to draw, started again, no engrave again. just a laser moving across. you can see it’s set at 800 speed and 100 power. but it’s getting 0 power.
Interesting, the laser doesn’t even move when it does it to me but the web app thinks it is working fine. Usually fixes with a couple glowforge reboots
winner winner chicken dinner. no idea how i missed that.
now, let’s see if i can repaste the job into the GFUI and line everything up properly so that the already engraved section can be ignored and won’t be a mess. otherwise this is a $20 piece of scrap walnut. and, of course, engrave #1 is at the top of the piece, so i won’t know until most of engrave #2 is done.
one thing i discovered, this being the first time i’ve engraved solid walnut, is that it burns very dark. at least this south american walnut did. must be a very resiny wood. i had it masked and the masking was incredibly sticky.
