Hi! I’ve printed a file on the Glowforge numerous times and it’s always taken around 38 minutes. It’s now taking 1 hour and 14 minutes. The final product is the same…what’s happening?
That timing appears to be the machine doing a double pass.
Welcome to the forum.
Does your design include engraves? If so, did you rotate your design? Also, it does seem like you might have a double cut going on since the time is basically doubled.
Thanks, I’ll check that setting
It’s scoring, and I moved my design, but didn’t rotate it. I’m going to check to make sure it’s not double cutting…thanks!!
