Thanks for this intro. You make it look easy, and it will be much easier for all of us because you did the hard work and shared your experience with us. You have given us quite a gift!
It’s both easy and hard … but I don’t want to mislead anybody; be prepared for some effort.
The alignment part is actually straightforward — as long as you’re careful to get all the finicky steps right. It does add a few minutes of work for each page. And it will take some practice before you can call it “easy”.
The hard part is the masking, which I’ll discuss later. It’s challenging on inkjet photo paper.
So kind of you to post this! It looks like a really fine way to get perfect alignment. I had forgotten about your three point positioning jig, thanks for the reminder. I’m looking forward to the upcoming parts of the tutorial.
What a well done tutorial! Thank you for the time you have taken to create it. I appreciate you sharing the knowledge you have gained through experience.
Thanks everyone for the encouragement. I look forward to hearing any suggestions for improving the technique or the tutorial — if anybody is crazy enough to actually try it!
Hoorah! @brok09, I finally found an inkjet photo paper that works well with transfer paper masking. Tearing is eliminated, and I can firmly roll the masking to avoid burn marks.
This cuts the effort in half, and makes the process a lot more reliable. It’s early days, but I think I’ll rarely have to deal with failed pieces any more, nor inspect all of the pieces individually.
As a bonus, the edge charring is much lower and I’m going to say goodbye to the salt tumbler!
Great news! I’ll order some.
I’ll try using thermal bonding on this new ink jet medium with hope of heat not damaging the image. I have managed to get the Kirkland ink jet paper to bond without damage. Haven’t figured out how to make spray glue work without getting it where not wanted.
Yeah, spray glue is way too messy. I haven’t tried thermal adhesive. This cotton paper bonds well with my usual pressure-sensitive cold adhesive sheets. Those are acid-free and very easy to use (peel and stick, then apply pressure with rubber roller or squeegee), but the website doesn’t warn you if they’re backordered.
Another pressure-sensitive cold adhesive option is a roll of Scotch 568. Also acid-free, but a little less easy to use.
