Kerfmeter cuts a 2cm Archimedean spiral and uses a motor to rotate it in place until it jams against the surrounding material; the angle at which the spiral jams allows Kerfmeter to infer kerf.
That is taking kerf measurements to a whole other level! Too much hardware for a hobby machine at least until it can be miniaturized but this would make sense for a large machine right now.
After printing a couple of the ones above, I found that variations in the specific sheet were more significant than the material type, and I just use 0.1mm for everything.
I set the width of the line to the kerf I want. Use Stroke to Path so there is a line on each side and use the one on the far side of the piece. There is still variation depending on humidity, room temperature, how long the wood has been sitting around, and probably more. But it is simple and close enough usually.
