If those were black reeds, it might look better, i just don’t like the contrast. (And I’m too cheap to buy 1000 of the black ones - they’re a lot pricier. Chuckle!)
I can probably hide the effect by raising the sides about half an inch though - I’ll give it a try and see before abandoning the idea.
I love that you made a knife block that is intentionally designed to hold knives in any direction or arrangement, but your knives are still put into it all facing the same direction and evenly spaced.
But I suppose it’s that sort of precision that makes for such beautiful work.
Or just drop a belt sander on the top. Should be able to sand the reeds down without breaking them since they’re packed in. A 3x18 sander seems like it would fit in there.
That is beautiful!! Any helpful hints on doing inlay work? At first I though that was just a solid engrave, it fits perfectly from the look of it (Can you sand it down if the inlay is too high?) Did you have to adjust for any kerf separately, or just engrave one image and cut the same image/shape out of the veneer and it fits well? (Is proofgrade® veneer adhesive?) Can’t wait to see what’s next !
I could have sanded it down, the inlay is just a little too high, but I didn’t for this one. That is just straight cut it out of the veneer and stick it in the holes. No kerf adjustments made.
The PG almost makes it too easy. It’s got a really strong 3M adhesive attached.
If your veneer is proud of the surface, can’t you just sand it down? Edit - after reading the whole thread i see that you said that yourself.
I plan on making one of these too, but i’ll be using wooden skewers - only about €1 (or less) per packet. The other advantage is that the skewers are pointed, so no danger of stabbing the knives into the end of one - they will automatically go between them.
