I’ve always found it annoying to chase down the plugs when I’m coming back to my desk with the laptop. This is a basic laptop riser with some cable-management keyholes.
This was made from a single sheet of Proofgrade Thick Walnut Plywood, using a kerf of 0.008" to get a tight, no-glue assembly.
I use a chunky plastic riser at work and this has inspired me to replace it with something more classy. How is yours working out? Anything you would change about it? Any tips for clean cuts or kerf adjustment on the thicker ply?
That stand is still in daily use. The original kerf value of 8 thousands is my go-to for the thick ply. Here’s a jig that I use for measuring kerf: HOWTO: Kerf Measurement and Jig
If I were going to change anything, it would be to extend the lower part of the cross brace through the leg and to secure it with a peg. I had to glue it in the end, since any horizontal play causes it to work loose. Trying to build without adhesives is a fun challenge, but practicality wins in the end.
