Large-ish (1.2mb) file errors out
Yes, the file in the original post of this thread has been mangled by Discourse stripping out its style sheet, which causes all of the paths in it to default to fill: black, stroke: none. It’s also apparent from the header that it has been saved “responsive”, so the size has been lost. But the OP presumably has the pre-mangled file and can do something like support suggests in this topic, although depending on the size they may get away with just a single bitmap engrave at a lower LPI.
