If glass is opaque to CO2 laser, should be able to laser front or back. Back would allow painting the etching a different color to have something showing boldly, such as a border design. Front would allow frosting like this that would actually also show in the reflection if viewed from an angle instead of straight on.
So I was unsure last night, so a quick forum search found these:
So I took that as no problem go for it, I’ll use this as reference if machine breaks and I need a warranty repair…(probably wouldn’t work as an argument, but in my head after a glass with the wife it did).
So I figured from the above and a few other posts it wouldn’t break the machine. So the other question is, is it worth ruining material. Since each mirror was 0.50$ each that fell into my “shrug, screw it, what’s worse that can happen” range of experimentation.
When I get time I plan to dicker with the defocusing.
