Laser cuts, then welds multiple l.ayers
I though this was pretty cool, considering it’s being done with a sketchup extension it’s quite ingenious.
cool
It looks like the finished edges are pretty smooth too. I couldn’t tell what the healing was doing. Maybe that?
There was a slight ‘bloom’ appearing in the middle of the stack, so I guess that might have been surface melting slightly between faces.
:upside_down_face:
Laser welding has come up a couple of times on the forum…if i recall correctly one of the sharper tacks figured out how it was done. (Had forgotten all about it, but it would be fun to experiment with one of these days.) :slightly_smiling_face:
And anything has got to be better than Weld-On #4. :smile:
I’m pretty sure if the laser welding has come up before, then someone dug up the paper on how they do it. http://hcie.csail.mit.edu/research/laserstacker/laserstacker.html This describes the technique used in the video.
An excellently written piece. Thanks for that additional info.
:upside_down_face:
Very cool. Looks like the move the surface out of focus, so the laser heats/melts rather than cuts.
:grinning: Here are few other posts… It is a very fascinating technique.
