I just loaded up a job, set the thickness to .128, put the cut operations in order (four of them), clicked print, saw a 56 second total time, went over and hit the glowing button…
…and the laser head moved to the extreme bottom center of the print area (about 10cm from my intended targets) and began firing on empty space. I interrupted it by opening the lid after about a second, closed the lid, let it scan, then went back to the interface and tried to print again.
…and the laser head moved to the extreme bottom center of the print area and started firing.
Um, what?
GFUI accurately represents what’s on the bed. Cut operations are correctly located, and there aren’t any stray “bits” of old cut ops anywhere. I can’t actually remember the last time I had a cut op down at the extreme bottom.
Am I cutting someone else’s design?
