Laser Not Firing - Please HELP
Laser head is moving around but laser is not firing. Cut was running fine then there was a click noise and laser stopped firing. Power is not set to zero and last cut was around 7:30pm EST on 10/20/25. Mirrors were checked and there is no cracking or melting. Please assist, thank you!
Sounds like either the power supply or tube itself has failed. It’s possible it’s a cabling issue, I recall reading about “the red wire” on the left side of the tube.
Although many owners have had their machines function much longer, 4 or 5 years is a fairly decent lifespan for it. Wiregrass seems to have the most reasonable repair options these days.
I think you’re right, I swapped the laser head and carriage plate from my other machine (which is also broken) and that did not help so I believe it is the power supply or the tube.
It is either a short of the red wire or the power supply.
I completed the Gift of Good Measure Print this morning around 6:40am EST with no luck. I have a video of the machine not working but it is too large to upload here. Glowforge, please contact me with assistance, thanks.
You’ll need to contact Glowforge directly as they do not monitor this forum.
