My pro is not cutting properly. it has random moments where the laser just stops working. this leaves gaps in the cuts. it is really really annoying when i am trying to cut pass through - wastes so much material and can’t just cancel and start the print again.
A few things could be going on here - the laser firing randomly is a return-to-mothership kind of thing, so let’s hope it’s something else!
Is that the front or back of your material? If it’s the back there could be voids that the laser can’t cut through
Are those copy/pastes of the same heart - or different art. If different you could have accidental duplicate lines and duplications will always cancel each other out.
The repair facility, yes, and boo. A staff member should be here shortly, but they’re going to want you to run the Gift of Good Measure (in your dashboard) on a piece of PG material. Post the time, and photos of it when you do.
By running a known piece of art on known material they remove a lot of variables that can be introduced.
Thank you so much for working through the instructions my colleague Jeremy provided, and for sending over the results. I’ve extracted the log files from your Glowforge to review your most recent prints. I would like to check over just a few more things. Could you do the following for me?
Please send photos of all your cleaned optical components, with special attention to any damage you might find:
Both windows
The printer head window, on the left hand side of the printer head
The laser window on the inside left of the Glowforge
