It does not matter what it is cutting, paper to plastic. The laser will not turn on, it will continue to run the tool path as if the laser is on, but its not. I cannot cancel the print. The purple light turns on and I have to unplug it or turn it off. This has been an issue from Day 1, but after several times of resetting, re-homeing and reloading the program it will run, however the 1st cut is always a success, then the other cuts are 1/10th the power and will never cut even half way through.
MAJOR PROBLEMS WITH PRO
