Leather filtered mask(s)
Inspired by the Hahns Atelier design linked to here: Making a steampunk mask / PDF pattern / DIY free
I modified it quite a bit, and made sizes, and shape changes, and and and - so I thought I’d share.
Background
My husband and I have been wearing these for a couple months now. First I made the “small” one (center image above) which is pretty close to the design above - and not actually small, but fits a narrower face, then I made the “large” one which fits my husband better (picture on the left) - the curve over the nose is shallower which allows more width while maintaining comfort.
The downside of both of those is they cover the majority of your face and you lose all downward peripheral vision. Also while they create a seal pretty well around the cheeks/chin - the area around the nose is pretty open.
So I created the compact version (right image). In this case the large is about an inch longer than the small, but other than that they’re identical. These are designed to sit on your chin, not cover it, and there is extra leather in the edging that fills in the gaps around your nose. I am able to make a solid enough seal that my glasses don’t fog up :slight_smile:
The filter is made from fusible interfacing. It was recommended as a good filter when cloth masks were first being suggested. You can easily fit two layers in, as they just tuck under the edging.
It’s sewn together with embroidery floss that’s been run through beeswax. It creates a solid seam that nothing is getting through! I’ll put links below to the specific things I’m using, but any sort of waxed thread will do it :slight_smile:
Instructions
  1. You can print out the shape on paper and put it together with tape to get an idea of which one will work best for you.
  2. Cut the mask portion out of stiff leather (I used PG thick)
  3. Cut the edging portion out of soft leather (I used Tandy’s milled single shoulder)
    a. With time stiff leather will soften, but you will not be able to sew this together unless you start with soft leather
  4. I clean the edges by dumping everything in a tupperware of salt and shaking it around.
  5. Cut off about a yard of embroidery floss and run it through the beeswax until solidly coated, then thread your needle
  6. Sew the smooth sides of the edging together at the nose and chin
  7. Sew the rough sides of the mask together down the centerline
    a. Shape the mask by curving it in your hand. When you’re done it should sit upright on its own
    b. You can insert the elastic now - it is easier than inserting it later, but means you have to deal with it while you’re sewing. Your choice!
  8. Sew the rough side of the edging to the rough side of the mask
    a. You must stitch every hole - so that your line looks continuous on both sides when you are done. Go through every hole going one direction, and then reverse and go through the same holes but with the thread on the opposite side
    ** This is especially important at the top of the nose and the center of the chin
    b. You’ll likely run out of thread after doing one edge here - go cut another one, beeswax, thread and go
    c. If you did not insert the elastic before - do it after you’ve sewn the two short edges, but before the tops and bottoms. Put the elastic in by lifting the edge
  9. Go wash your hands - even after the salt bath, your hands are dirty
  10. Now set the nose. Make sure the center seams match up, and then move the leather around until you have two tubes on either side of the nose channel - use your thumb to set it.
  11. Insert the filter (yes, this will mess up the nose, but now you know how to put it back!).
    a. Make sure there isn’t a big bump in the middle - if there is, that’ll brush against the tip of your nose and/or lips. Nobody likes that.
Right click and save as for pattern
Face mask_All_V2
When loading to the :glowforge: it comes up with a mask error…I didn’t use any masks, so just ignore
The settings all come up as cut - and in a different order than this - this is how I rearrange them
Tips and Tricks
  • Expect to break needles. Have spares :slight_smile:
  • You’ll need about 2.5 times the amount of floss for the distance you are sewing - so you can estimate pretty easily how much you’ll need. I tend to sew the short sides, then the top, then the bottom. No need to try to do it all with one thread!
  • Instead of tying knots in the floss I wrap about an inch of the ends through the stitches. It will trap it and not leave a bump
  • When sewing the edging to the masking, whether you tie a knot or use the technique above - make sure it 's on the mask side. You don’t want anything extra rubbing against your skin!
  • Before you put the mask on for the first time, work the leather at the nose until you’ve got an opening you think will fit yours. I find that the width of the pad of your thumb is often about the same size as the width of your nose - so start there!
  • You will mess up the nose just taking it on or off the first few times, but it “sets” in position after a week or so.
  • You will always mess up the nose changing the filter - it will go back to the set position with some fiddling.
  • Change the filter if it gets damp. If still dry, I leave it in the bright sunshine to (hopefully) sterilize a bit!
Links to products I used - in case you need them:
Beeswax: Beeswax and Holder 2/Pkg. - #411464
Thread: Amazon.com
Needles: Amazon.com
Soft leather: Milled Veg-Tan Single Shoulder — Tandy Leather, Inc.
Pellon (filter): https://www.amazon.com/Pellon-721-Mediumweight-Fuse-N-Shape-Package/dp/B0857LH92Y/ref=sr_1_33
1/4" black elastic & PG thick leather
Thank you for the file, instructions and supplies list. I am sure many will find this valuable.
Thanks–great idea & all the info & pattern appreciated, but I don’t recommend wearing leather mask for the summer/hot weather–reports of many experiencing heat stroke wearing even just fabric masks in hot weather… But should be great in the fall & winter (if we still need them).
Nah, no breathing difference between the two - and as you are made of leather…
What an involved and great write up/description. Thanks so much for sharing the file and all of your work on this.
Thanks so much!
But we have larger holes to breathe thru even with our untanned “leather” skins… And I do love leather & love this concept, but just passing along info making news in other countries about increased risks of heat stroke when wearing face masks…
Excellent!
Hannibal Lecter : [on telephone] Well, Clarice, have the lambs stopped screaming?
I’ve now worn this mask all summer, and even during ice hockey (well, practice) - it’s a bit darker than it was - plus I painted the outside, and it’s very form fitting now! :slight_smile:
Hi,
I noticed that you used a Pellon fusible in this project which is 100% polyester. I would like to laser the Wonder under 808 (100% polyester, very thin) after it is sandwiched between two layers of fabric, but I’m nervous about cutting polyester in my GF. I’ve been searching around for a straight answer and I thought I might just ask someone directly. Are you not concerned about the warnings related to lasering polyester? Also curious if you’ve had any concerns about burning whatever the adhesive is that is on the fusible? Maybe I’m being silly to worry this much.
The word polyester stuck out to me in this post. Though not really the same as what you’re asking about, perhaps my experience might help.
Thanks for the response. As a farmhand, myself, it’s pretty cool to see the Glowforge being put to use for farm work!
Do you vent to the outside or use the air filter? Are you confident that there aren’t any health risks or risks to the GF while cutting polyester? It appears as if a lot of people are cutting polyester, whether it is safe to do so or not. There doesn’t seem to be any immediate concerns, at least. I’ve read about chlorine being released when lasering polyester and I don’t know if the people cutting it aren’t aware of that or they’re just not worried about it. I’ve also seen lists of material that aren’t safe for lasering that include a lot of poly type materials. I’m just confused :\
I hope I’m not hiijacking the original post with these questions!
I vent to the outside. I sort of left the research part to my son-in-law, who is a professional mechanical engineer. I made sure he knew the components of the fabric and that he would determine if they would all be safe to laser. He chose this particular material based on that. The machine buckets that I cut are done quite quickly…as they are simple cut files with no engraving, so with good airflow and venting, it’s over and done with pretty fast.
I suggest you just type the word polyester into the search bar in this forum…it’s going to bring up several other posts about polyester. Hope you find the answers you need and your confusion becomes lessened. :slightly_smiling_face:
I didn’t end up lasering the Pellon (though I could have) - but AFAIK there isn’t an issue with polyester and the laser - PVC (poly vinyl chloride) is the big no no - is that what you’re thinking of?
I have definitely lasered polyester felt with no issues.
Thanks so much!
Thank you! They look great! :smiley:
Ahhh. Mayybe. I thought the chlorine comment was tied to the person cutting polyester. But maybe they were also confusing it with PVC. Thanks for your help!
