Pictures here
Its for a blade 32mm across by about 115mm long. You should be able to stretch it a little in the new interface.
Three layers - score, holes and outline cut.
SVG below
Pictures here
SVG below
Thank you for the share. Awesome project.
Thanks for posting and sharing. The colour of the leather is very attractive.
Thanks for the nice share!
What settings are you using on your leather
Thick leather proofgrade settings
Cut Speed mm 168
Power 100%
Engrave Draft Proofgrade setting
Speed 300
Power 16%
Seemed to work fine
Thank you for sharing this project.
Very nice, thank you for showing/sharing your work!
Thank you!! Stay healthy, Stay safe!
Hi,
Could I get this SVG pattern? I could not find a way to download it.
Thank you.
Where is says:
Svg below
And then a picture of a bunch of dots…that is the file.
