My lid came unglued. Got it back on and plugged in the ribbon cable attached to lid. Lights would not come on. When I looked closer it looks like this connector got fried. Is this a correct assumption? Is it hard to replace? Where can I get the connector ? TIA
Oh that bites ![]()
You’re going to need to reach out to actual Support.
I don’t believe that is commonly available as a replacement part, but a few folks who are skilled in electrical engineering were about to do so.
wiregrass made has the pc board it is $65.00
It is interesting that the board is available. That is probably the most common source of magic smoke. Very freqiently the case in posts that start with “I was deep cleaning my machine…”
I got the two screws removed to replace the board but something is holding it there when I try to remove the board. Any advise on what I should do next? Thanks
