This happens when the machine hasn’t been able to contact the mother ship.
Are you showing Offline? Is your WiFi up and running? I’m going to presume you’ve been through the WiFi steps before so not list them all out here, but if not, let us know and we can walk you through them.
Yes I’ve gone through the wifi setup several times… my setup is the same as it’s been for 3 years… it works… I’ve also turned off my VPN and gone through the setup again, holding down button to get it to teal then go through the wifi setup etc etc… it says it’s connected… each time… but nothing
Still says Lid Open
I should add that I sent it to Glowforge for another reason… when I finally got it back it then came up with this new problem… I have been sent a new lid cable… I’ve fitted it… all the lights are on
