My son is asking me to make him a light saber (Darth Maul’s) with my GF. He wants layers cut out and glued together to make a 3D lightsaber. I’m willing to bet someone somewhere has done this before, but I can’t find anything similar in searches. Mostly I find clip art or svg files designed for the Cricut, completely one dimensional.
I know several of you have done layered designs, so where would I start? I need some Yoda wisdom here, or else point me to a file I can purchase, as I can’t find one.
Was thinking you might be able to get a free 3d model off of thingiverse and use the slicer to chop it into layers for you. But I can see it possibly causing some issues on the buttons and whatnot depending on the level of detail you want. If you used a thin material it could look really cool but be a bit of a mountain to put together.
You don’t need fusion 360 to use the slicer. I made my husband download the slicer the other day to show him how he can take his 3d files and cut them in the gf. He doesn’t have fusion 360.
Looks like it would be pretty trivial to create something close by using a dowel or pipe and laser-cut rings. Take an image, do some basic measurements, create cut file. Looks like you’d need 6 or 7 different sized rings for the end caps, same for the mid sections, and a few lateral fins. The buttons could be single cut from 1/4 material.
you say that NOW. however after 1500 hours of design fiddling, construction fiddling , and general and generic fiddling , until you get the finished product . you WILL be singing a different tune
so figure in about 1500 hours. we’ll all be hiding.
