I made my own stock by sandwiching acrylic with maple veneer and then lit it from underneath with an under cabinet led.
I then realized that I needed a pretty storage box and custom fit packing materials. It was supposed to be a nice simple present, but it got a little out of hand. I had a blast and used a fortune in materials figuring it all out.
I’m sure you do. I can’t illustrate to save my life. I’ve been working in graphics for decades and every designer uses the tools at hand: stock images, existing designs that they modify or repurpose, etc. No one can do it all.
I used Adobe stock images for the dog and other parts (there are three or four stock images used to build the etch on the acrylic lid. I printed out more than a half dozen test tiles to find the correct etch settings). I bought box and tree plans from Etsy shops that I adjusted and modified to fit my design. What I really did was think, envision, plan, modify and repeatedly test everything out. I probably built most of the design three times over before getting even close to a finished piece.
And then, even at the end, I realized that I forgot to factor in the height of the box frame into the fit of the tree height. It was 3mm too tall, so I had to go back and adjust the tree design (bought from Etsy) so it was the correct height, without changing other parts of the design. (My refuse test pile was more substantial than the final work.)
