I did a lot of slot and tab till discovering that fingers are much stronger, but unglued all are very much weaker. just twist a bit and the best slot and tab does a hula dance.
The file is the image : Save as on it you will gain the . SVG.
Not SCa, LARPing ( I know the difference is seamentic by t still) but I am searching a way to make a full samuraï armor for LARPing, if possible using the GF. But at the moment, nothing revealed itself.
It is, and it isn’t, material wise, doing it in leather isn’t that interesting (quite heavy) and need tonnes of lacquer (which adds to the weight) and is essentially a museum grade armor (which isn’t what I am aiming for) else, would be plastic (surprisingly recommended for SCA-Larping) but there, there isn’t much material option thats is both performing well as armour and performing well as laserable. For example acrylic is great with laser, but is quite sharp and shatters in multiple pieces. so y a, haven’t found what yet.
You need to right click and Save as (svg) - some browsers won’t have the svg option, if yours doesn’t then try a different browser. Edge, Chrome, Firefox, and Safari all work.
