I’m loosing my mind with this project. I am wanting to engrave a piece of live edge fir (It is under 2” thick so I removed the crumb tray) with a map. I have done dozens of test engravings and finally got the right setting. I figure out how to align the image to start in the right spot as the camera/alignment were off with each cut (due to the height is my guess). When I FINALLY started the big project the image was so blurry and illegible. If I know the image position and what the material height is….why won’t the GF engrave the image as a flat image?
Please help if you have run in to this and found a solution
Did you prop it back up so that the top surface is within 1/2” of the laser head? Material height is measured from the top of the crumb tray, not the bottom of the GF.
