I’m having issues with my machine not cutting through material in the top left corner. I’m using PG material & settings. I’ve done a thorough cleaning & still having issues.
That can sometimes happen if there is any warp in the material at all…are you using the honeycomb pins to pin it down flat when you can?
No, I normally use the rare earth magnets when needed. The 12x20 pg material seems to fit snug & lay flat. I will have to find the pins & give them a try. Thank you!
I swear by them…I haven’t had one (PG) fail to cut through since I started using them. (All bets are off on goofgrade materials.) ![]()
So far so good! thank you so much. You saved the day!
Awesome!
Thanks for the tip @Jules. I’m going to close this thread - if the problem reoccurs, please do post a new topic. Thanks for letting us know about this!
