Hi, I made a file for a coaster but I don’t know what to do from here. please see the file.
the outline I need to cut, inside a line and 50, i need to scare but machine recognized all one file so I cannot set differently. I only have the option to do one thing altogether.
So the way to separate tasks in the GF user interface (aka the GFUI) is with color.
Try this. Click to download.
For more information go here:
Thank you very much for quick response. I will read and try!
All three of those lines will come up as “cut”. That’s because they have a line (stroke) color, but no fill color. If you want to score or engrave, you can manually set that in the GFUI. If you read through that document I listed it will tell you everything you need to know.
It works! seems like this file will help me a lot.
Thank you again!
No problem. There is a lot to learn at first, but you’ll figure it all out with some practice.
