Totally accidentally cut the score line - but glue fixed that! My roommate was the one who made it (with my “help”) so I’m gonna poke her to post a picture
Welcome to the forum. It is hard to tell what went wrong, but there are a couple of things to try. First, make sure your material is absolutely flat. Any warp in the material will affect the cut. Next, make sure the medium draftboard is selected as the material and that Proofgrade settings are being used. Make sure also that your lense and mirrors are clean. Finally, I suggest using the set focus tool since even Proofgrade material can vary in thickness and is affected by humidity.
You can run a second cut if the first doesn’t go through if you haven’t moved the material at all after the first cut. Some people try lifting the cut piece out with double sided tape or a sharp tool to make sure it is cut through before moving the material.
Hey! So im new to at this and i might feel really stupid but did you post the templet on here? Ive been trying to make a business card holder but I haven’t hand any luck.
Oh and this is my first post on here!
I just made this as my first cut on the medium draft board and it is so beautiful and so detailed. My only challenge was putting it together. The grooves were so exact and tight, it wouldn’t quite go together all the way. Did I do something wrong? Or what’s the trick in getting the grooves to all fit?
