Trying for cutting 1/4 inch thick plywood on my glowforge aura, Im using the thick basswood setting and its burninb my wood even with the mask, any tips?
Some plywoods just aren’t laser friendly. The glue, voids and knots will never cut with a laser, and the Aura is pretty challenged by 1/4" material.
Thanks, I didnt know that
If the plywood itself is not to blame you can try many passes at a higher speed, there is diminishing returns however. At extreme need with my pro I first engraved a quarter inch down and then cut after that in order to cut some half inch plywood because it would not cut deeper by cut alone. I have also made as many as a dozen or more passes in order not to melt the Delrin I was trying to engrave.
