Hello, I am new to Glowforge. I have a question about the manual settings. I am trying to make a shelf with white birch wood veneer core plywood. 1/4" thick.
How do I know what settings to use when I am not using the proofgrade materials from Glowforge?
In general terms, the answer is testing, testing, testing. Luckily in your case, the PG settings for Thick Maple Plywood should get you in the ballpark.
Hi and welcome to the group The surest way to get an idea of the effect of different settings on different materials is to try different settings on different materials. I put this together and use it on every new material and keep them in a box for reference.
There are woods that you might cut through a half inch thick, but I would not expect birch to be among them. And even then they should hardly be on anyone’s early projects.
You could get 1/4 inch Baltic Birch and make two and glue them together to make half inch. As it is plywood anyway you now just have more layers.
In that case my notes above about making yourself a test strip should tell the tale. In general more passes are diminishing returns which is part of why cutting half inch material is such a problem. One pass at 145/full sounds in the ballpark but your experience may differ.
It takes a bit of work to set up that testing the first time but you leave it in the GFUI and you can use it on each new variety of wood and have a ready apples to apples comparison. If it starts a coal at 100 or 120 speed that will show also and be a warning against doing that, but for that reason you have to watch that first test like a hawk, plus what is happening while it is cutting is instructive if more ephemeral.
I used to order that plywood. I was never able to get consistent cuts on the 1/4in. It had a lot of voids and filler spots. I was running 125 speed, full power on a pro for cuts, but even then some spots wouldn’t cut completely and edges were blackened and required a lot of cleanup…
The kerf on most scroll saws is a lot more than the kerf from the laser, however a jeweler’s saw is pretty close, Normal for a Jewelers blade is extremely fragile and takes a lot of practice not to break them constantly, however what is considered heavy for a jewelers saw is still very thin and far more forgiving, and not that expensive. The key fact is that the saw needs to be the same 3d direction unless moving and can change direction only while moving and that needs to be forward. I frequently use it to clean up places that did not cut through especially having to cut filler,
