Manual Settings on project changed
Has any else noticed manual settings on an older project changed when brought up to cut again? I have some test files that have manual setting so I can dial in new batches of wood. I have 5 of the same objects, each set to a different speed - an example, set to 140,145,150, 155, 160. I brought up 3 sets of these to cut, and in each one the speed settings had changed - example above changed to 143, 149, 153, 157, 163. This was not done by me. Any thoughts?
There was a discussion of this after a speed change by Glowforge around May. Your results should be the same even though the numbers have changed.
