As you can see, that bottom line was eyeballed perfectly. Then as the head went back and forth, the fans slid the boxes left side just a hair on every single pass.
My proposed solution to fix this is I bought some maple veneer and I’ll simply cover the bad burn up.
My question is this:
What does an engrave on maple veneer look like at pg settings? Could I engrave the same image onto the veneer without burning through it, with similar darkness or should I just cut a piece to fit, cover it, and call it a day?
The guy has already seen it and is willing to just give it to the family and apologize for the mishap with it. He even said that we’re it not for the border, he’d have just tried to pass it off without saying anything.
While it may look like it, that’s actually a completed box. The angle looks like a flat piece of wood. Also, he buys from Amazon and has them delivered to me. They come with usb drives embedded in matching wood. I then just engrave the tops, the bottom of the boxes(as seen above) and the usb wood enclosure.
I purposely left the root and two branches spots to see if he can spot them, but I missed the D, &, both Rs, and the P. But you can clearly see the masking in the picture.
I don’t think the fan is doing that, my guess is the air assist is just barely brushing the top of the box as it moves across. I’d try it without the crumb tray next time – just boost the box up so the top is within 1/2" of the head and use the Set Focus tool to set the height.
The box is roughly 1" in height. Tray was out and it was sitting on top of three white tiles to bring it back into range. It sits pretty low in the 1/2" range. Tiles seem to be fairly slick. Didn’t think the box was that light but it apparently is. If i have to do another single like this, I’ll probably use the masking tape to two surfaces and glue them to each other trick.
Also, I showed up this morning at church and handed it to him and he loved it…but also had just handed the other 5 to a family member who was headed somewhere else about 2 min before I got there. Ah well…he still would have needed to copy all the files onto the usb stick anyway.
