Mat Cutting
The beam is a fixed size where it passes through the lens and then gets focused down to almost a point, creating the cone. If you defocus then it will be bigger at the bottom, so actually more steep sided. Not sure what effect it has the shape of the cut though. It may cut less at the bottom and give a bevel that way.
Would the laser burn the mat and discolor the white?
If it is a material that is removed by burning, like wood and cardboard, then yes.
And if you are really, REALLY into mat cutting:
Really really, really into mat cutting! $70,000 + :fearful:
Yep, really really REALLY really.
You can give the illusion of a different color created by the angle cut as in my example posted awhile ago.
please tell Eddie that I love his ā€˜garden fire’ comic.
Thanks for referring us back to that! I’ve bookmarked posts so I have a better chance remembering that! Though, I’m not setup for air brushing! :slight_smile:
