I went through all the default settings before experimenting with power levels and whatnot.
When that didn’t help, I decided to try defocusing the laser.
I started at 0.2", then 0.3", up to 0.4" for a 0.118" thick piece of MDF.
I had to increase the power / lower the speed to compensate, but I ended up with a super smooth engrave, that only took 2mins for a 1" diameter circle.
I have another, similar project in mind that I’m planning to try that method. The issue I foresee is that there wouldn’t be any kind of texture on the surface of the stones, so they won’t paint very nicely.
But while I have you here. A) thanks for the great work! and B) have you had any luck using this technique to get bases with beveled edges like the games workshop bases???
Ahh ok. The main post was a 3" circle, it took 11 mins.
As for the bevels, I haven’t tried it, but you should be able to just engrave a (white->black) gradient of the appropriate width and then cut around it?
I have wondered about this too but never really looked into it.
