I took my mirror out and cleaned it. When I tried to replace it it slid in slightly askew. It is sitting like it should but blue indicator tab is rotated about 15 degrees to the counter clockwise. I am afraid to apply pressure in any direction.
I am waiting to hear from tech support.
Has anyone else experienced this problem? I thought that I was following instructions precisely and was very gentle.
If you hold the base down with one hand and pull firmly but gently backwards in the direction of insertion, (45 degree angle), you should be able to back that out without hurting it.
Did it twist while it was going in? You might just be experiencing the magnetic attraction…that has to be overcome.
