More compact version of the “Template to NOT measure the kerf”
To save material, I made a new, more compact version of the “Template to NOT measure the kerf”. It fits along the side edge of the cutting area, and has both metric and imperial markings.
The first version has separate pieces:
tightness-test-compact
The second has them joined zipper-style for easier handling.
tightness-test-compact-zipper
The final version is more fine-grained, focusing on a narrower range of kerf measurements, because in practice, I find it’s almost always in the .09mm–.14mm range:
tightness-test-compact-zipper-fine
Awesome, thank you!
Thank you!!
Thank you!
Thank you so much!
Awesome, thanks!
