Thanks…I already did remove the original background, but perhaps as @paulw suggested, I should add a light colored background back into it.
This is the original colorized photo, which I turned into BW.
Didn’t really do much at all to it other than change it into BW. I’m discovering here that the background may be the problem.
I believe the tool you’re looking for is called “Flood Select” in Affinity Photo – the equivalent of the “Magic Wand” select for Adobe users. Ideally, it will let you select the pixels that are a near-match for the top of his Dixie Cup and adjust the tolerance until you get what you want. Or select the background, adjust, and reverse the selection…
Here’s a vector outline. The facial features should be a separate layer from the profile.
This makes perfect sense and I thought of doing something like this. I have actually worked with images where I had to trace certain features and create separate layers…however, I don’t have an auto-trace feature in AD…is that how you made this? I could do it with the bezier pen tool, but it wouldn’t be as easy as an ‘auto’ tool. Thank you so much! I downloaded it, but now that brings up another question…is there a special trick to getting it to align perfectly over the original image?
I drew this on my wacom with a pen. Don’t you have an iPad pro and an apple pencil? I got one a little while back and I’ve been using Adobe Draw and loving it (except for the multi-touch shortcuts… ugh)
No good trick to line stuff up if it is two separate files. Eyeball it. the thicker outline should give a little leeway.
Or keeping the original art in a layer in the file. That’s probably a good methodology.
hmm. Discourse seems to be stripping the bitmap data from the SVG files. Here’s a PDF with the image still in place on a different layer.
Daddy Christmas 1919 withAssests.pdf (4.5 MB)
I have both a Wacom and an iPad with pencil. I’m still hanging tough learning to use the Wacom. After I spent that much money on it, I owe it to myself to learn how to use it…and use it well. (Love the Apple pencil). Thank you so much for both files…you do good work! I very much appreciate your time on this. I will be sure to post my (hopefully) successful engrave. You have provided me with something fun to try out…and as always, I’ve learned more new things. Always an adventure!
Thanks! I just opened AP for the first time last night, so not surprised that I wasn’t aware of that tool…or of any tool for that matter. I will be looking around more as time goes by.
That is wonderful! Yes, the challenge is that a white hat on a white background (or transparent background) is going to be like a sheep in the snow.
You might try experimenting with sharpening. This will create distinct regions around the edges that will make the engraving more distinct.
I suddenly have a craving for some hot wings after seeing this picture!!! Wonder Why???
Awesome!!
I’m not real happy with the eyes or mouth on this one. That is why if I am going to continue doing this I’m going to have to become a script and filter guru.
Interesting. It is kinda creepy looking.
Did the original have a red-eye issue? Or a light reflection bouncing off the top of the irises?
The smile was likely a contrast issue due to the white teeth which got compressed in the final image with not enough levels to get the teeth.
Just a thought… And I mean that… I’m working ATM so I haven’t tried this.
What if you B&W the image, then copy that onto a tan background, then maybe color-match to give you a possibly-more-accurate preview? I dunno. It’s a thought-in-progress until I get to PhotoShop.
Or just become a set decorator for horror movies. There is a fine line between creepy and adorable.
@Xabbess , I finally got a chance to mess with the photo of your dad and took the background out and sharpened it up a little. I’ll upload the png file of it if you want to try it as an engrave and see if it works.
(It might come out darker than you expect because I deepened the shadows a bit to give a larger range. And it’s a pretty large file…it might need to be reduced in size a bit.)
LMK if it works.
Daddy Christmas rev. 1919.zip (1.1 MB)
Wow…! Jules, thank you so much…that’s incredibly kind of you to take the time to do that. I tried medium and dark settings before and neither of them really worked. Any thoughts on settings? I’ll be thrilled if this works.
I haven’t done too many photo engraves, so I’m not sure from this point. (Maybe you could try both, really small, and see which one works best?)
And hey, it’s your dad…
I know. Bless his heart. Speaking of that…I sure hope you’re getting along better and better every day.
I’ve uploaded the png and it looks great, so far. I will try different settings and see what happens. Will keep you in the loop. Thank you, again.
honestly i’d find an artist and ask them to do some restoration work for you, or perhaps even have a painting done from the photograph (perhaps digitally, which you can sometimes find quite affordably). the problem you’re having, i think, is that the contrast (both on the original and on jules’ version) is quite low - that is, if you counted all the individual shades of grey and plotted them on a line to show how far apart they are, you’d only find a few dots clustered around each other. that means that the laser doesn’t have a lot to work with in terms of showing detail.
