Total newbie here, trying to figure out the best way to mount wood signs & plaques that are 1/4” thick (some are slightly thicker).
I like these no-nail sawtooth hangers, but I’m afraid they might go in too deep (description says 1/4” depth)
What do you all use for lighter/thinner signs/etc.?
Hey, welcome, we like newbies.
As always, your best resource is right here, the forum search:
https://community.glowforge.com/search?q=picture%20hanger
You’ll find this right at the top:
I am looking for picture mounts to hang pictures for my projects made on the glowforge and clamps to hold wood to the honeycomb. Does anyone know where I can find files for this?
Seems to be right up your alley?
When I had a light sign I wanted to hang, I found some hangers that I could just glue on.
I believe I once saw a design where someone even cut the pieces to glue on for hanging, but I have not tried that.
This one (which comes up with @evansd2 ) links):
Just to make it more legit, here’s a file for some keyhole hangers that I designed and included on this thread:
In a nutshell, I needed a way to hang some engravings and didn’t care to pound in/screw in traditional hardware. So, I made a stacked keyhole design. This is not a true keyhole in that the back is not engraved to create a slot for the head of whatever is sticking out of your wall. This is a two piece design with a larger slot in the back over a narrower slot in the front to mimic th…
This is what I was hoping to find ~ minimalist hardware that can be glued. Do you have a photo or link?
I saw the file for the laser cut mounting piece, but would rather stick with hardware so I don’t have to worry about matching wood when using a purchased plaque.
I couldn’t find the exact hangers we used, but it was something like this:
Something that had plenty of surface-to-surface contact for the glue to hold.
We used “Goop” for the metal to wood glue. (Easy clean up and strong hold.)
Perfect - thanks so much!
I wanted to do frame wire and went with the following:
25x14mm D-Ring Hangers
Tiny screws, Flat Head, Phillips Drive, (2.5×6mm, 0.1×0.23inch)
Small Screw, BLUELEC Antique Style AntiOxidative Finish Wood Screws for Fastening Plank, Plastic Materials or Resin Plywood, 45° Flat Head, Phillips Drive, 100pcs, 1/3 Inch(2×8mm, 1/3", Gold): Amazon.com: Industrial & Scientific
Frame wire
Picture Hanging Wire #2 100-Feet Braided Picture Wire Heavy for Photo Frame Picture, Artwork, Mirror Hanging, Supports up to 30lbs - - Amazon.com
The screws are small enough they don’t poke too far through, but every thing feels strong enough for my pieces, as long as they don’t get too big.
This is my go to. Easy to source and strong.
system
Closed
July 18, 2021, 1:12pm
11
