So I have been happily modifying my workspace to accommodate the new pro ‘Enterprise-1701’ – Since this one has a passthru slot I wanted to be able to move
the GF ‘out’ to allow for the longer wood, so I built an ‘extend-a platform’
(The silver box behind the platform is a flat exhaust system to outside the house, I am adding a flexible vent pipe that extends and retracts)
Speaking from experience… since the feed is from the rear on the Passthrough jobs, if you want to use the Pro on the large (48") sheets you need at least 6 feet clearance in front of and behind the machine…so I put mine on a table with castors that could be pulled out away from the wall when I need to do a large project. (It’s an obscenely tight fit in my little office…I have to take the french doors off to get out when I’m running a job. Otherwise I just stay in the office until the job is done.)
Untrue. Many passthrough jobs aren’t 48" long, and you can “pass into” for those. I routinely cut things that are 23-24" in passthrough without moving my machine at all. Even if you do have a project that is cutting the full 48" length of the sheet, you can get away with far less clearance in the rear. Just feed it from the front, you need something like 30" in the rear, because the front 18" or so are inside the machine already.
Yes you’ll need to wrangle the “one way” (ish) flaps, but that’s easy enough.
In your case, you don’t even need the huge clearance in front either, because you can just push the Glowforge back as you cut instead of moving the material (drawer slides, man).
Ideally, we’d all have huge workspaces… but we don’t, so you have to adapt. @Deleted, you’re the perfect person for that, you’re good in an improvisation situation.
The first-bit cut will go to the front of the machine, and since you can load it front to back, the 48" needed can start near that line at the front of the machine. I keep 30" from the back of the machine to the wall and haven’t found much need beyond that.
My original setup was the exhaust just going out a window, so I used some heavy canvas to cover the rest of the window. Even though it was a pro I found it easier to put the extra cloth between the lid and the door.
As it turns out V-8 juice containers are exactly the correct diameter to fit the 4" fittings on the Glowforge exhaust and most other similar sized fans, through fittings, etc. and hold on very tight but are easy to remove or replace and transparent as well so there is less need to replace them.
