Let’s see. What is it Glowforge can do? Taken right from the main page, brief comment on actual functionality, if known.
Design with just a pen - Glowforge’s onboard cameras can cut & engrave directly over top of your drawing. From a doodle to a diagram to a masterpiece, you’re one button away from a finished product. Or, scan drawings and resize, clone, personalize & edit them right in Glowforge software.
- It’s in there. We’ve seen it numerous times, now.
Precision Preview - The camera shows the actual material on the Glowforge bed so you can drag around your design with your mouse or finger. Align it perfectly & see what it will look like before you hit print.
3D Autofocus - The lens moves as the laser travels, so you can cut & engrave materials that are curved, uneven, or irregular. Glowforge’s dual cameras measure the thickness of the material to a precision of four one thousandths of an inch.
- Measurement and fixed point autofocus already there. Multi-Point Auto-Focus still being completed, so far as I’ve last heard. It could also be that they have turned on MPAF on production. Either way, the hardware has the capability, so it is programming.
Recognize materials - Glowforge’s cameras recognize a variety of specially-coded materials, plus your iPhone or laptop for perfect settings without any guesswork. It also supports presets for other materials you use regularly.
- It’s in there. We’ve seen it numerous times, now. Unknown how many ‘other matierals’ and phones/laptops are in there currently, but it’s in there (as the old commercial goes).
Catalog - Personalized designer jewelry. The perfect shoulder bag, with customizable compartments. Lighting, housewares, art, party goods, furniture - no art degree required. The Glowforge catalog lets you buy & print intricate, beautiful designs.
- It’s in there. We’ve seen examples of it, though we know it isn’t fully released, yet. This is coming for full release, soon, and it looks to have amazing growth potential, too.
Compatible - Work from your Mac, iPad, iPhone, Android, & Windows or Linux computer with JPG, PNG, PDF, EPS, & a host of other file types from software like Adobe Illustrator, Inkscape, Adobe Photoshop, GIMP, Autodesk, & Sketchup.
- It’s in there, at least so far. The cloud platform has made it cross-platform compatible for interfacing with the Glowforge, and people have apparently used every platform and program listed, and some not listed.
Just one plug - Glowforge uses a regular household outlet & connects via wifi. Cooling, fans, & everything else is built in. Use without ventilation for materials like stone & glass, or ventilate out the window for materials like acrylic & leather. Or, add a Glowforge Air Filter & cut anywhere.
- It’s in there. Shown to be true in all demonstrations, Beta, and PRU. The last update even reads like the filter powers from the Glowforge, so even with the filter, it is only 1 plug and wifi.
Optical Alignment - The dual cameras align the laser head with the frame, with your design, and with your material. Glowforge realigns with every cut and engrave, adjusting timing and position, so every print comes out perfectly.
- It’s in there. It seems that part of the big claim to fame is this and #2, which seems unique to Glowforge. Need work? Maybe, and that’s in the software.
Precision within a kerf - The laser works by removing a hairsbreadth of material, called the kerf. Glowforge knows this and compensates, so if you draw two puzzle pieces, they’ll fit. Even better, the Glowforge can measure the material thickness so 3D objects slide together perfectly.
- It’s in there. This has been demonstrated with PRU. It seems the biggest variance is the material itself or the user.
3D high-res engraving - Engrave complex, three dimensional curves with 1,000 DPI resolution. To get perfect detail and sculpt with real depth, Glowforge can carve away material with multiple passes, each one focusing more deeply than the last.
- This has shown to be there, and greatly improved over the last 6 months. Expecting CAD/CNC precision, based on this description absolutely is moving the goal posts. This is an art/craft tool, not a precision engineering tool (for all that some things can be done with amazing precision).
Safe for schools - Under US Food & Drug Administration regulations, Glowforge Basic is categorized as a Class 1 laser, like a DVD player, so no special precautions are required to use it. The Pro model is Class 4 device like other lasers, and requires additional precautions.
- It’s in there. The Basic, as a Class 1, is as safe for schools as a DVD player or computer optical drive.
Air Filter upgrade - The unique Glowforge Air Filter lets you put the Glowforge anywhere, no matter what material you’re cutting. It snaps right under the Glowforge and makes it just 7" taller. It’s $750. Alternately, you can use the Basic model near a window with the included duct.
- Apparently this is all true, too. The Air Filter may be shipping later than many units, but it is a separate device anyway. Apparently it is just about ready for full production, with the bugs and issues worked out, and performing as advertised. Also, even without the filter, both Basic and Pro can use the duct for outside venting.
So there are a couple promised details needing the software to be completed, but the known limits are software, not hardware, so it is reasonable to expect those to continue to be resolved, and the rollout of those features would be very smooth as it is all cloud-based.
Overall, the only feature that I know was not active in last communication was continuous realtime autofocus, and that is a software thing, not hardware.
Things not originally promised that have been added (not-exhaustive list)
- Additional materials for delay
- 3rd party gift card for delay
- Additional gift code good for materials or design store for delay, incrementing with each month unit readiness and shipping is delayed by them.
- ‘Blast Shields’ for Pro, providing complete laser containment and safety when the passthrough is not in use.
- 1 set of Class 4 laser safety glasses for Pro (and option to buy more).
- Additional 6 months warranty.
- A Class 4 safety guide for home use, something they initially said they would not do AND does not exist anywhere else in the market.
No, I say they are performing, and continue to produce and improved. I will not conflate optimism, even misplaced or unreasonable in retrospect, with deliberate, planned, or conscious deception. A lot can change between expectations and reality, especially on timeline, when you are creating something entirely new and bringing that to production for market.
