Hi, I’m new to using my Glowforge Aura. I was working on some keychains for volunteers at my organization. I started by printing just one and it came out fine. I then copied the text and printed another 3 at the same time and those also came out fine. I wanted to print another 4 (after the changes with the new preview function was release) and this time, the text is not lining up correctly.
I selected the Thick Maple Plywood material. I lined all of the text up with the keychains. After I hit print, the alignment shift. I cancelled print, realigned and hit print again. All looked to be aligned correctly this time. When I printed, the text on the bottom and top keychains were misaligned (top was too high and bottom was too low) but the middle one was for the most part aligned correctly.
The only thing I think could have changed was the new release of the preview function.
Can anyone explain why these would not be aligned correctly, especially when I’ve don’t this with multiple keychains once before? It seems counterintuitive to have to print one at a time.
I’ve looked at some of the topics and they seem similar but slightly different.
PS, I recently cleaned the rails with alcohol wipes.
Thanks,
Vincent
