When I first got my glowforge, I cut some MDF with a hole in it to fit in my window to use as a vent. But I could not just place it in the window, because there is a lip all around the window. From the top, it kind of looks like this:
A rigid piece of wood could not be put in it. If I used wood that was thin enough to flex, it would not insulate much.
So I had to make it in multiple parts, and put each part in place, and screw them together in place.
So it looked like this:
It worked, but it was pretty âpermanentâ. To remove it I would have to remove the screws and it took more time than I wanted.
It was not a good solution.
I was playing with foam floor mats (making weapons for the kids), when a light bulb came on. Why not use these for the vent? You can find these mats at any hardware or walmart.
So I took one, cut it to size with an exacto knife, cut a hole in it for a vent fan with the exacto as well. I made 2 that were the same (so I could double up the layers). I made them fit snugly. It took me 10 minutes to make these, and they work like a charm!
They flex enough for me to put them in the window. They easily come out when Iâm not using the GF. And they seem to be fairly well insulating, because I canât feel a draft coming through the window at all. I think it was a âbrilliantâ use for this material!
Hereâs what it looks like with the window closed:
I opened the window and took a top down picture.
Itâs not see-through though. Anyone know where I can find see-through foam play mats?
Iâm lucky that my window is not that big. Perhaps with a larger window, you could connect a few of these mats together, and cut those to size. If you use 2 layers, you could make sure the seams are at different places.
It works great for me. Your mileage may vary. ![]()
but so far Iâve just drunk the coffee.
