So here’s my problem.
I have been cutting parts out on the Glowforge for several years with very little problem.
The other day, I cut several designs, and then had to use the Pass-through feature for the first time.
No matter what I tried after the first cut, the auto align would not find the first cut, and the manual alignment cut about .250 inches off. Even though the screen showed alignment.
Frustrated I gave up for the night. Next morning, switched the Glowforge on, and nothing.
Its either stuck in scanning or centering. The screen will not update.
I’m able to load the file, set the cutting features, but the unit will not going any further.
I had gone through all the steps to clean, align, check wifi, reboot with no results. Its still dead to the world.
Has anyone have this type of problem, and have you found a solution.
Any help would be greatly appreciated.
Thanks,
Ed Balling
