My Lid Came Unglued - How can I fix?
And here I am!
@grandmaster the simplest way to make this work is to unscrew the hinges from the machine and glue them in place on the lid. The hinge guards come off with a little effort, pull one side of the guard towards the other one, then pull down.
You’ll want to find the best epoxy/glue you can find, then after all is fixed and put back together, don’t forget to recalibrate your camera, since the lid will be put on slightly different than its original placement.
I wrote some steps on repair, but my hinges apparently we’re easier to adjust than yours, so again, I’d just unscrew them and glue them to the lid, then the torque of the lid and screw studs on the machine should help with positioning.
