Could you share a photo showing the back of the acrylic so we can see how close to cutting through you are getting? If you have made sure that your honeycomb tray is properly installed, that your material is held perfectly flat and that you have the correct Proofgrade settings, I think Glowforge will credit you for wasted materials.
Okay I will post a photo tonight. It happened on three different pieces. When holding it up to the light I could see light through the cut line. At first I thought maybe the tape was the only part not cut but once I got a better look I realized it wasn’t cutting through the acrylic itself.
I’m so sorry to hear that you’re running into trouble. I’ve extracted the log files from your Glowforge to review your most recent prints, and compared it with the details you’ve provided.
I’d like to take a look at a specific test print, to ensure your Glowforge is performing within specification.
Could you please do the following?
Turn off your Glowforge, then turn it back on
We included an extra piece of Proofgrade Draftboard with your materials shipment for troubleshooting. Place Proofgrade Draftboard in the bed and load the Gift of Good Measure design.
Set the score and engrave steps to ‘ignore.’ Print the Gift of Good measure using the default settings. Allow the print to finish.
When the print finishes, leave the lid closed and wait until the fans stop and the picture of the bed updates.
Check the completed print:
If the Gift of Good Measure fails to cut, please let us know the date and time of the print
If the Gift of Good Measure cuts successfully, please try another print of the design you saw the issue with, and let us know the results.
If the issue still occurs, please let us know the date and time of the finished print.
Once the print has been completed, please let us know how it goes! We’ll extract the logs from this print, and send over the next best steps.
