I often have to do large batches of items. Many times these items have to have exact measurements.
On a number of occasions I have gone to run these items and needed to reposition them, and somehow resized them ever so slightly accidentally, and it went unnoticed. A few hours later when the job is done, out pops a few dozen unusable pieces.
Can we have a button to turn on resizing for items that is off by default? That would save me a lot of trouble and material.
This would be very helpful as it is so easy to resize inadvertently. Moving with the mouse is faster for me, but I use the arrow keys to avoid accidental resizing.
I have run into this problem occasionally but double check the scale at the top particularly with many one that is off should be seen. When that happens I undo if it was the last one or delete the sized one and copy paste one of the correct size.
Didn’t realize how much I needed this until just now.
I have only ever found one use for the built-in scaling tools: making cut lines to chop up scrap pieces. Since you cannot specify size, or do non-proportional scaling, I find the provided feature almost completely useless.
