Finally got around to making a design that I started long before my first GF arrived.
It holds two sleeves of Nespresso Vertuo pods (but could easily be re-scaled for the small ones) and uses 4 neodymium magnets to mount it on the side of my fridge. I cut this one from locally-sourced scrap acrylic, but could be made from any material(s) that strike your fancy.
Base: Set black and green to cut.
Top: Set black, red, and blue to cut.
Use the squares (stacked as needed if using thin materials) to create the required spacers.
Enjoy!
Standard Reminder: You are welcome to use this pattern for personal use only! You may not post these files anywhere else, including Facebook, Etsy, or eBay, nor may you sell physical copies of this design.
Neat - sadly our fridge isnât magnetic
Hmmmm - if you did a wide circle at both ends you could do a FIFO systemâŚwhich if you drink coffee frequently isnât an issue, but we sometimes have pods around for months and months!
just the front isnât or the whole thing? the front of my fridge isnât, but part of the side is exposed to the counter next to it, and the sides of my fridge arenât SS.
Yes sadly. Non-magnetic SS on the front and non-magnetic black plastic on the side There are a few spots that are magnetic where, Iâm guessing, support bars cross behind the plastic
then my six-year-old wouldnât be able to reach them to make me coffee! unless it is mounted to a lower cabinetâŚ
Eventually I will make an under the counter box sleeve holder. Because I probably could be responsible enough to throw a box into a box! we have the older pods. I dig your design.
Thanks for posting the file. Is it possible to share as a PDF? I saved this and opened it in Inkscape and it is 3x the size. I can open it directly in Glowforge Dashboard, but was hoping to add some wording. Thanks
Another mounting idea: While Iâll need to verify the available space; Iâm thinking of cutting small holes in the corners and using screws to mount under the cabinets, just above my machine. Not the easiest way to see pod collection, but definitely saves space.
