Some of you may have seen my earlier post regarding the Roland Boutique synth stands I’ve been making here: Roland Synth Stands
Further to this, I decided to make a custom stand for three Eurorack Synths (Behringer analogue originals/reinterpretations) using a single sheet of 1/4’ ProofGrade ‘Thick Black Acrylic’.
After designing in Illustrator, I exported the SVG to allow for the cutting itself, the cutting of the screw holes and even some countersink etching.
I used the standard ProofGrade settings for the print, aside from slowing down the cuts ever so slightly since I’ve had a few instances in the past where a print doesn’t cut all the way through the entire design.
The resulting rack works perfectly - certainly as well as the $79 Moog Mother-32 Rack Kit, and is almost identical to the forthcoming Behringer EurorRack Stand.
…and yes, I can still get to all the sockets and ports on the back of each!
nice work.
I am inspired by this. I have a few rack-able mixers, input devices and maschine controllers that would benefit from some racking. I may have a width issue as some are wide like yours and some are the next smaller size. but, I loves me a good challenge. so…
