Here is another take at the no crumb tray lineup that can return a material back to its spot when it was one the crumb tray and lined up in the corner. This v2 design is my misinterpretation of @evansd2 design suggestion but it works and I will try again on the collab I actually like this design better then the v1 I posted with the feet for the crumb tray.
Yes, I do write with sharpie in the base of my glowforge. It comes of easy with magic eraser And yes, I messed up a little on 3D printing the top of the edge of the piece but it still gets the job done.
If you want that prototype (the one in the photo) then you can just have it for the cost of shipping. I was going to throw it out. It works just fine but I already have another piece I made and am making others of difference designs. I just like finding different ways to solve a problem Maybe one day I will make batches and sell them. Just DM me the address you want it sent to
A minor note: I’ve seen “braces” like this cause minor but hard-to-identify issues if they slightly flex the case. For example, I found an issue with camera alignment after experimenting with these on one Glowforge.
Just to say: if you’re using it, and you are troubleshooting something, be sure to check it out as a possible culprit.
That is great to keep in mind! I was not aware on that one. So what about thoughts on this other version from last week where the lineup is just using the foot slot from the crumb tray?
