Thank you! I’m taking a look now, and based on what I see here, there may just be a firmware update needed. I can make sure that happens from my end. Could you please do the following?
Turn on the Glowforge (no need to press the button on top, only the switch on the back)
Thanks again. I’m truly sorry for the repetitive steps, but could I please have you run through the steps at setup.glowforge.com one more time? Because the firmware update is still needed, I expect you’ll see the “Glowforge didn’t Connect” error again. When you do, please press the button on top of the Glowforge once so it stops glowing teal, and leave the printer on. Thanks!
Excellent. The update is complete! Could you please log in at app.glowforge.com and tell me what you see?
I want to apologize again for the unusual situation here. I’ve let the team know about what happened so we can get to the bottom of it. Thanks so much for your help troubleshooting.
Please note: it may take another minute or two for the Glowforge to finish applying all updates and be ready to print. Let me know what you see in about five minutes!
I’ll do that, thanks. I set a score line on the PG and used the Set Focus command. From here, I could hear the head move for the measurement. It’s good so far!
