Mix it with a solvent and brush it on?
I was thinking that, or possibly lay down a layer of clear coat sprinkle the powder on then top coat it with clear afterwards.
A real tale would be a tiny bit of cobalt carbonate, especially with a bit of borax… cobalt at 1/1000 is almost black while 1/50,000 is detectably blue, while boric acid forms a glass with silica even if nothing else is added and is frequently used just to form a shiny surface sealing a wide range of clay bodies.
Even if the tile glaze did not melt, the borosilicate might be hot enough to form a bond. No doubt if measured by the light of the moment, the air at the point of contact is easily 5k degrees C but the key is measuring the glaze even a quarter inch behind. Aluminium melts at under 500C so painting some Aluminium foil and hitting it could be very revealing.
Painted aluminum foil test. it was a score test speed 250 power starting at 10 on the left and going up by 10.
Was there any melting? 500 C would do it.
Yeah you bet, it started poking holes in the foil around 20-30 pews and i shut it off at 90% as it was just blasting it away. I wonder what would happen if you did this on bare aluminum tags? would you be able to etch it? I worry about reflections, but if it can be done at say 30-40% power it might be ok to test.
That was why I was thinking about the paint, that it would absorb reflections.
If you can find 20 mule team borax (not boraxo that is soap) or boric acid roach powder that will make a glass if you have it in a binder. Wood glue might make a black(after burned) binder, or gum tragacanth that I used before but had to add a serious oxidizer to keep it from being black.
That is awesome! So much depth!
Is it meant to be a “real” Popeye?
No I would not. About the only thing I leave running if I leave the room is the lights… and maybe the tv… and sometimes the shower… well the coffee maker runs…
I’m not sure. It’s a pretty cool piece of art for sure.
Wow, that engraved really well! I need to find some time and paint to try this! You guys seem to be getting some really amazing results!
Our local Walmart carries it.
It is commonly used in laundry. Just make sure you get the borate and not as a friend did, the soap.
One is good to turn into a glass that would remove oxides from molten metal while the other is just a burning mess, that my friend could not understand why it kept messing up his gold castings.
That turned out mostly ok. I don’t see any banding on mine. I used a medium layer of paint… Then after a couple hours I put a lighter coat on. And then I waited about 24 hours before I pew-pewed it at 225 speed / 25 power / 430 lpi. Roughly 2 hours to finish.
These are all awesome. I tried one a couple of days ago but it didn’t turn out…I can see now my settings were way off. Can’t wait to try it again.
Thanks!
My wife uses it in making a laundry detergent.
haha awesome
Wow! I just got my Glowforge so getting into the basics. But I’ve been a professional Ceramic artist for over 42 years. Most of the commercial tiles you are using are high fired clays. I work in low fire so the clay is “ softer” ( non tech term lol) . And the surface glaze will be different. Unfortunately my time is rather booked at the moment but I will see if I can experiment later with low fire tiles and see if they can take a design better. Another to do list for my machine. Meanwhile this is fascinating.
